Clutch parts
slk
Clutch parts
Post by slk »
I may be in need of pressure plate and clutch plate for my 62 M37. Can you get those at NAPA shops or do you have to go to a military specialty shop. Also is it a tough job to do if you are mechanically inclined?
Steve
Re: Clutch parts
Hi Steve,
Easy job if you're mechanically inclined. Less expensive to get one from Midwest Military as opposed to NAPA or other stores. Change the release bearing too-Timken 2065. You will need a clutch aligning tool. The tranny input shaft is best, ask John at Midwest about it if you order from him.
milstencil
Re: Clutch parts
Post by milstencil »
