Swap to an NP205
Swap to an NP205
Has anyone swapped their Transfer Case to an NP205 and if so, which one did you use?
Re: Swap to an NP205
I don't think you will see that mod because the NP 200 is an excellent tcase that never breaks and the out put for M37 is offset for the rear axle. the 205 doesn't have the offset output. IMO its not worth the work. Not an upgrade. they are almost exactly the same design except the 200 has no wimpy aluminum. ;/)
