So finally getting around to putting my truck back together and am getting close to putting the wiring back in. I have the Greek harnessing that Sid Beck sold before he died and used to have the diagrams he sent with them but had a hard drive crash so they are lost.
Does anyone happen to have them digitized? I believe its just one circuit that is color coded wrong but dont remember exactly what one it is. Hoping to avoid finding it the hard way with the meter haha...
Anyone have Sid Beck's Greek Harness Diagram?
Re: Anyone have Sid Beck's Greek Harness Diagram?
Color coded wrong? It must be the black wire! Ha.
I didn't know his were color coded. You can chase it with a meter and the stock diagram. But that Will likely be time consuming.
Yeah, the Greek harnesses were color coded wire instead of wire tags. Its about the only concession i have made so far, front and rear harness was $150 bucks and in perfect shape. Can deal with some color to save $1k haha. Of course I bought the harness 10yrs ago and lost the paperwork
- HingsingM37
Just saw this post. Do you still need? I believe i have it somewhere. If i recall there was an incorrect wire to switch at the rear? If I locate I can scan and send them to you.
Take care.
Take care.
I do still need it, that would be great if you wouldnt mind scanning it!
Thanks!
Thanks!
- HingsingM37
I will begin the hunt for it..
- HingsingM37
98taco3,
p/m sent. thanks
p/m sent. thanks
