Page 1 of 2
1953 M37 Project
Posted: Fri Mar 13, 2020 11:47 am
by Sokoji
So I'm new to the site but I just picked up an 1953 M37 from an estate sale, it was the last of the collection so as you can image its pretty rough but the price was right. I'm not sure how to post pictures yet but when I do I'll get some up. Got it dropped off and have been taking it apart because it will need a bunch of work, still trying to decide on the direction i'll be going to get it fixed up. Currently the motor is seized, thought its not the original motor as far as I can tell, the block starts with L23 and from what I looked up that means it was built in 1958. It has an artic hard top from what I can tell and a pretty nice bed thats just floating on the back right now. I'll probably have a ton of questions but I'm excited to get to work on this.
Thanks for having me.
Re: 1953 M37 Project
Posted: Sat Mar 14, 2020 1:25 pm
by welderdave
is this the one from that collection in seattle.
Posted: Sun Mar 15, 2020 4:27 am
by NAM VET
congrats, and lots of help and suggestions here. I did a restoration on my own M 37 over the past few years. I went back and read years of old posts for hints and suggestions. As for posting pictures, one way is to go to post image, log on, select upload, then go to library, click share, and in the selection of link for forums, select it, on a Mac, then command/cut, then go to your post select image, then command/V and your picture will be there.
A few links to this simple process.
https://postimages.org
all the best,,, Hal Copple
Posted: Mon Mar 16, 2020 12:26 am
Welcome Sokoji!
Post your many questions here! Also, please add your location to your profile so we know where to route you for parts vendors and such.
Thanks for saving another one!
Posted: Mon Mar 16, 2020 6:13 am
by Sokoji
Posted: Tue Mar 17, 2020 7:11 pm
by Sokoji
Thanks for the warm welcomes.
welderdave wrote:is this the one from that collection in seattle.
Yes, it was the parts rig from that collections.
Does anyone know a good source for getting the mounting pads for the bed?
Posted: Wed Mar 18, 2020 6:38 pm
by ashyers
Sokoji,
You can contact:
Midwest Military:
https://www.midwestmilitary.com/
Vintage Power Wagons:
https://www.vintagepowerwagons.com/online-parts-catalog
They are good for one stop shopping and very knowledgeable about M37's. I'd suggest you pick up some manuals and parts books, it will make your life much easier! One nice thing about M's is that most of the parts are available and once the truck is sorted out they don't eat too much if you drive 'em regularly and keep up with general maintenance.
Enjoy your truck!
Posted: Wed Mar 25, 2020 8:12 pm
by Sokoji
Thanks for those links to the two suppliers, they seem to have every part you could need.
So been taking the truck more apart to get to the things that need repaired. Found out that the engine is from a vehicle made in 1958 and everything on it is 12v. Replaced the rear springs as they were exploding out from rust. Gained a few inches in height in the process.
Still trying to break the engine free, the head is off and I tried soaking the pistons in 50/50 atf/acetone for a week and still can't get it to budge. Dropped the pan and pulled off the piston caps to see if it they were seized to the crank, luckily they werent, crank and bearings look pretty good so far. It appears the pistons rings are rusted to the bore. Got some metal rescue and filled up all the cylinders, I guess I'll see if it get rid of the rust.
Curious about the front and rear axle ratios, while I was replacing the springs I checked them and it appears for one rotation of the tires the drive shaft spins just shy of 4 times. It should be almost 6 times for 5.83 gears from my understanding.
Posted: Wed Mar 25, 2020 8:47 pm
4.89 gears are a popular upgrade in the M37 axles-perhaps you have a set of those contained within.
Posted: Wed Mar 25, 2020 9:30 pm
by Sokoji
Cal_Gary wrote:4.89 gears are a popular upgrade in the M37 axles-perhaps you have a set of those contained within.
That's what I was thinking as well, and it would be nice if it was 4.89 gears, but the driveshaft turns something like 3.9 turns for every one full rotation of the tires so it doesn't match up with any ratio I know of. Only ones I know of are the 5.83, 4.89 and 4.30.
Posted: Thu Mar 26, 2020 12:55 am
Oh, and your rear fender bolts are 3/8 NF. Welting goes between the fender and the bed. Midwest Military or Vintage Power Wagons should have both.
Posted: Fri Mar 27, 2020 7:14 pm
by Sokoji
Posted: Sat Mar 28, 2020 3:06 am
by Elwood
That's the first
external combustion flathead that I've ever seen.
Posted: Fri Apr 03, 2020 5:40 pm
by Sokoji
I was checking the brake lines and they are pretty sketchy. Does anyone know the size of the line and the nuts for the flares? I'm thinking of making some new lines.
Posted: Mon Apr 06, 2020 3:29 am
Easier to just buy pre-made, armored lines as a set. John at Midwest Military has them.
