Brake line set rocks!
Posted: Sun May 25, 2008 6:02 am
by HingsingM37
Yesterday I installed the brake line set I got from John Bizal. What a time saver! To try and make my own lines would have been crazy. I got my old lines out and layed them on the floor. Luckly I tagged them with more detail than some of my other parts. I matched up the locations and started from the rear axle and moved forward. All of the lines matched up excellent with little or no "tweeking" needed for the fittings to thread in. The lines had the armour guard on them as well. The only glitch was I installed my y-adaptor on the front axle backwards. This did not allow enough slack for my brake hose to mount to the crossmember. I turned it around and all fit well. I highly recommend this set
Posted: Sun May 25, 2008 6:08 pm
by refit1701
I just got this set and it looks great. I should be installing it shortly.
Posted: Mon May 26, 2008 10:07 am
by bubba_got_you
got any pix? I need to get one
Posted: Mon May 26, 2008 5:27 pm
by KenInGA
This probably gonna happen to my truck soon. Good to know that John Bizal's work well. I may just go ahead and get a set.
Pics
Posted: Mon May 26, 2008 6:13 pm
by HingsingM37
Bubba, I posted some pics in my album since I still have not figured out how to post them here. Look under 'David Cial ' album.
Posted: Thu May 29, 2008 3:46 am
by ChadNC
FWIW, I just ordered the fuel and vent line set from MWM and would also highly recommend it....great looking product.
Chad
Posted: Thu May 29, 2008 1:06 pm
by mattveeder
I got mine from VPW and they sucked.
Posted: Thu May 29, 2008 7:31 pm
by Lifer
You just put your finger on the problem, Matt. The fuel line is
supposed to suck, but the vent line is supposed to
blow.
