Front Prop Shaft
Posted: Tue Nov 15, 2016 4:52 pm
by sturmtyger380
I keep digging into the M37 I have down here in South Carolina. I have all the floor covers off and noticed the front prop shaft is really gnarly.
Anyone have a good front prop shaft they would like to part with?
Alan
Re: Front Prop Shaft
Posted: Tue Nov 15, 2016 5:14 pm
by isaac_alaska
most driveshaft shops can probably cut the bad section out and rebuild it for you for fairly cheap. i definitely wouldn't run it like that! it'll twist off in a second haha
Posted: Wed Nov 16, 2016 5:25 am
by BILL L
Email me I might be able to help you.
Autodoc51@aol.com Ocala,FL
Posted: Wed Nov 16, 2016 12:22 pm
by Drew M.
To cut down a driveshaft at a shop is inexpensive (~$75). However, replacing the pipe or adding length is $$$$$! IMHO: Get a used driveshaft.
Posted: Thu Nov 17, 2016 5:53 pm
by Oddball-CmK
I believe I have one, the first one pictured without the yoke. If you're interested, $65 plus shipping.
Regards,
Cordell
Posted: Fri Nov 18, 2016 6:11 am
by sturmtyger380
I have a couple of leads at the moment but I will get back to you.
Posted: Fri Nov 18, 2016 2:56 pm
by xm708
If everybody falls through I have at least a dozen !!
