Voltage regulation?
Posted: Thu May 15, 2008 4:10 am
Guys;
I've got a question regarding voltage regulation. I have a 1962 M37 with a 230 CI flathead industrial engine installed in place of the original engine. I bought the truck this way. Now, this engine does not have the normal looking setup of a generator and voltage regulator mounted on the firewall. In fact the generator itself appears to be different as well. My concern is that since I see no voltage regulator, has someone simply rigged this truck to run without a voltage regulator. If this is the case, then I am in danger of the batteries exploding correct?
Now, I have heard of internally regulated generators/ and alternators, and am thinking (hoping)maybe this is the case with my truck. Unfortunately I don't have a photo of my setup, or I'd include it here. I'll try to explain it as best I can. My generator is identical to a 60 amp alternator listed in MVM magazine. I'm using the term "generator" because it says "60 amp generating system" on the ID tag on the unit. The unit does not have that large cable running to it with the 90 degree elbow which attaches just back of the pulley, but rather it has two or possibly three wires soldered to the back of the unit on top in a spot that has posts that appear to look as though wires were meant to go there. I know this doesn't say much but thats the only way I can describe it. This wiring setup connects via a coupling to the main harness and I assume then somehow feeds the batteries etc.
Is there a way I can tell if I am getting voltage regulation from this unit by checking voltage to the batteries while the truck is idling or revving etc? I have heard that a certain voltage to the batteries is normal under charging conditions but what I don't know is what do I look for to clue me in that something might be wrong. I hope I am explaining things right. Anyway any info you could provide will be appreciated.
