Whats the correct speed sign for the M37, the one that says On Post Speed Limit etc?
And where exactly did they go , or most of them go? Thank you , Jay
Correct Speed Sign on Dash
- carolinamv
- SSGT
Re: Correct Speed Sign on Dash
That isn't an ordinance item. It would go, if it was required, where the local command ordained it.
isaac_alaska
I think there should also be a plaque that lists maximum top speed in each gear, but i don't remember where it is installed, because i think mine is missing
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
That's the "Transmission and Transfer Gearshift Instruction Plate", which is mounted on the dash panel, above the steering column.isaac_alaska wrote:I think there should also be a plaque that lists maximum top speed in each gear, but i don't remember where it is installed, because i think mine is missing
- carolinamv
- SSGT
Right,
So when command wanted them where did most of them go and what were the speeds for the M37? Thanks guys
My M37 had a decal center of dash below windshield "Max Speed 45MPH"
Have also seen it in stencil.
Tom
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
- carolinamv
- SSGT
I thought I saw some that say Max Speed and On Post Speed or something like that. I might be over thinking it.
