Floating power ????
cweber2
Floating power ????
Post by cweber2 »
1963 m37 front engine mount has stamped in it Floating Power ! What's that ??
Re: Floating power ????
It has to do with Dodge's engine mounting system. The axis of the engine & trams is arranged in the mounts to reduce vibration. If you check out some old ads on YouTube they cover it well!
Agreed-most any engine with the "sandwiched" rubber mounts is considered "full floating power".
cweber2
Post by cweber2 »
Thanks for the info !
Kaegi
Post by Kaegi »
chryselr invented the idea in the 20s or 30s and some other car companies actually paid them to use the technology.
Cal_Gary wrote:Agreed-most any engine with the "sandwiched" rubber mounts is considered "full floating power".
The Chrysler patented "Floating Power" concept involved the mounting geometry, not just the rubber isolation mounts, as ashyers noted.
