Page 1 of 2
So you think you're having a bad day?
Posted: Sat Mar 05, 2016 11:58 am
by w30bob
Hi Guys,
I thought you'd get a kick out of this (I did). My buddy bought a 5-ton to play with and figured he'd go fording. Didn't turn out so well.
I'm not sure if he plans to drain the pod or hire a wrecker to get him out.
Re: So you think you're having a bad day?
Posted: Sat Mar 05, 2016 12:10 pm
by isaac_alaska
and THIS is why you should always check to make sure that all fording gear is properly installed and functional before hitting the ponds! might want to think about a snorkel for the driver as well...
Posted: Sat Mar 05, 2016 12:19 pm
by w30bob
Or maybe start out with a shallower pond!
Enjoy,
Posted: Sat Mar 05, 2016 2:49 pm
by carolinamv
Wow, yeah that's done for a while
Posted: Sat Mar 05, 2016 2:53 pm
by Elwood
That must have been a cold swim to the edge of the pond.
Posted: Sun Mar 06, 2016 8:37 am
by T. Highway
Oh man, that's going to cost a few bucks to extract and fix.
Keep us posted on this Bob.
Posted: Sun Mar 06, 2016 9:53 am
by Jess
Ouch, With these old vehicles, just because you can ford in deep water, doesn't mean that you should. The maintenance after a successful deep water crossing is extensive and none of our older stuff should be subjected to that. Even shallow water plays havoc with brakes and other things that you don't think of. Only the government can afford to play like this....
I'd like to see the recovery pictures posted, an the work required after to clean it up.
Posted: Sun Mar 06, 2016 11:14 am
by just me
Hope they get that out before all the fluids leak out into the pond. I bet the owner has no clue how much stuff is going to need a complete teardown after this!
Posted: Sun Mar 06, 2016 4:51 pm
by ashyers
Maybe I should have done that with the M37 on purchase. Sure would have helped get decades of cement like mud off!
In fact the students wanted to test the fording kit in the school's pool... I suspect I would have been fired.
Posted: Mon Mar 07, 2016 12:25 am
Sadly, I've seen all sorts of adventures like that when I did tank recovery-guys fording gamma-goats with the hull plugs out, etc. The bilge pump was running but couldn't keep up with the inbound water as he went down, leaving the right-rear corner sticking up above the surface. We made the driver drag and attach the winch cable himself, to acknowledge and reward his brilliance.
Posted: Tue Mar 08, 2016 2:48 am
by HingsingM37
Yikes! Has he got it out yet?
Posted: Tue Mar 08, 2016 6:08 am
by w30bob
Hi Guys,
Well..........I talked to a friend of my friend and they got it to the edge of the pond, but apparently the banks of the pond are a bit steep. And they discovered the brakes are locked due to lack of air pressure........so dragging it up the bank against its will is going to take some doing. I suggested they plump a pump into the exhaust stack and make a pretty pond fountain for the kids to play in this summer.
later,
Posted: Tue Mar 08, 2016 1:09 pm
by T. Highway
I hope they can attach a glad-hand to air up the brake system, or they will need to cage the actuators. The best idea may be to excavate a gradual slope to the ponds edge to simplify the removal of the truck.
Posted: Tue Mar 08, 2016 5:02 pm
by w30bob
Hi Guys,
Ok, got an update. Pond drained. Truck extracted by bigger trucks. NOW the fun begins! I wonder what Army TM covers how to deal with submerged vehicles?
I'll see what I can do for pics without getting close enough to be considered a "volunteer" to deal with this mess.
Posted: Sat Mar 12, 2016 3:15 am
by Tom P
Get it out yet?
I expect to see it on e-bay soon.
"Perfect condition clean never mudded"
Idiot!
Tom
