farm truck rustoration
Re: its rebuild time
that's what ive read
I don't like the look of that
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Just go with OD green Trav it'll match the rest of the truck.
I am putting a racing cam in my engine so I was thinking hemi orange
but I will probably go with OD green
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Almost any color would be better than silver. at least in my opinion.
you have to remember that silver is historically correct
but if I wanted a correct truck I would be about 10 to 15 K in debt already
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
my uncles boss installed my cam bearings
and my uncle steam cleaned my block
and there was chunks of cast in my water jacket
but they look like they are not part of the block we are thinking they are from the sand mold
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
fished out cast chunks out of water jacket
valve guides in and I saved my old intakes
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
I got my valve seats ground
tried to install my new cam and the hub on the cam is 1 1/8
my old one is 1 1/16 so the keyed triangular piece that the cam gear bolts to doesn't fit
I'm at a stand still right now
but I'm going to pull the front cover off my extra engine and see if I might have one
other wise I'm going order one on Monday
if vpw doesn't have one ill have to have to have mine machined out
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
no progress today
but we got some wood to keep the garage warm
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
going to order my part today
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
vpw says they have never seen a 1 1/16 cam hub
and last part is ordered
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Travis,
So why do you have a 1 1/16" diameter cam hub? What is the remedy?
because my grandpa measured wrongT. Highway wrote:Travis,
my part to resolve the problem came today
more progress tomorrow
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
cam is in
6 valves are in
freeze plugs in
re-insulated the wiring
I need a wiring diagram so I can figure out what is what
what is the best way to prime an oilpump
6 valves are in
freeze plugs in
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Is it a gear type pump driven by the distributor? If it is open up the pump and put some assemble grease in there where the gears are. That way it'll have some suction and draw in the oil.
