i need more power
52PLOWERWAGON
i need more power
is a 318 swap a good idea ?
what kind of gas mileage does a 318 get in an m37
- W_A_Watson_II
Re: i need more power
A 318 is plenty of power. The one time I checked mine (39.5" tires and 5.83 gears) I got around 8.5, that's with 3,000 RPM = 60 MPH.
52PLOWERWAGON
what if I went w/4.89 gears ?
does your M have the stock tranny ?
how hard is the 318 swap?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
- W_A_Watson_II
I'm running an NP435, but it and the stock are 1:1 in 4th.
As for dificulty, it depends on if you are buying the conversion kit (http://www.uglytruckling.com) or doing it yourself.
W_A_Watson_II wrote:A 318 is plenty of power. The one time I checked mine (39.5" tires and 5.83 gears) I got around 8.5, that's with 3,000 RPM = 60 MPH.
that's brutal mileage
granted I do need a personalized license plate that reads : SLOW2GO
- W_A_Watson_II
Yes that is bad, but is was back with the Holley Crap Injection. I suspect it will do better now, but I need to fix my broke ARB Locker and find the electrical gremlin that occurs on very hard jars that causes the GM TBI fuel Injection to quit.
52PLOWERWAGON
whats the best donor vehicle?
I prefer carburetors over fuel injection and points over electronic ign
(due to simplicity)
(due to simplicity)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
I would start by looking at class C motor homes if I was looking for a 318. last fall I picked up a 1994 32ft class A with a injected 454 with only 24,000km for $1
52PLOWERWAGON
I aint buying no motor home I was thinking more like a pickup truck
would I want a 1/2 ton or a 3/4 ton?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
- W_A_Watson_II
My Donor was a '68 with an NP435, Points and single barrel Cab. I converted it to MoPar Electronic Ignition and TBI Fuel Injection.
52PLOWERWAGON
what model?
- W_A_Watson_II
52PLOWERWAGON
thanks so any dodge w/a318 and a manual tranny will work? correct?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
- W_A_Watson_II
All depends on your clutch and transfer case plans. I had to build by own mounts to accommodate the hydraulic clutch.
52PLOWERWAGON
Will the stock tranny mate to the dodge 318 bellhousing ?
And do I really need a hydraulic clutch ?
Does the radiator retain its stock location ?
Will the stock bellhousing bolt up to a 318 ?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
