stronger lifting shackle brackets?
There is a "heavy duty" shackle bracket for the M37 that has a 1/2" thick base instead of the 3/8" on the original. It is also cast from steel instead of iron. It is FSN 2510-973-4188. Does anyone know where to obtain these? Supposedly they started to use them in '62.
Re: stronger lifting shackle brackets?
Sounds like a good item for MM to reproduce.
You haven't lived till one snaps off whilst using a towbar behind a 5-ton...
DG
DG
That's why I bought the tow bar adapters that chain around the axle.
Good idea, but you can't make the angle work behind a big rig.Cal_Gary wrote:That's why I bought the tow bar adapters that chain around the axle.
dg
I just picked up a pair of what must be the improved version for the rear. One on the truck had been welded and the other was broken. The "new" ones were substantially thicker and also had a P/N in the casting. I suspect when one of those things snaps it must be exciting. At least the bumperettes will slow it down a bit.
I have them on my truck. Best thing about the steel ones is they bend before they snap. ( Don't look at my roadside bracket.)
- Site Admin
Hmmmmm, you give me more Fabrication credit than I deserve, Maybe you meant MWM?? LOLPoW wrote:Sounds like a good item for MM to reproduce.
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Andy,
The brackets he's talking about are the ones on the front of the truck, where the top of the bumper meets the frame rails.............this doesn't apply to the rear shackle mounts.
06,
I put up an extensive thread on this subject a few years back, with all the detail differences between the two. In my case I was looking for the thin original ones for my truck, not the later, better ones. The better ones are easier to find, as I assumed the Army did a good job of retrofitting all their M37s with the better cast steel mounts. I'm sure John at Midwest or VPW has them.
06,
