Wheel bearings
Wheel bearings
I have some good used matched sets of wheel bearings. Matched cup and cone as they were removed. I know its not great to use used bearings but since they are matched there should be no problem. Bearing sets are very expensive and if you are on a budget or for a play truck these will work. Also some differential bearings. Wheel bearings $10 ea diff. ones depending on what I have plus shipping. Autodoc51@aol.com
