W.I.I. Olive Drab mystery...
Posted: Wed Apr 29, 2015 11:37 am
by Oddjob
Re: W.I.I. Olive Drab mystery...
Posted: Thu Apr 30, 2015 4:12 am
by Carter
It is an electric motor that drives a generator and based on the fact that it's electric motor input is 416 volts at 400 cycles 3 phase which is used in most military airplanes and the generator's output is .25 KW at 75 volts DC, I would say it was used in some kind of aircraft to power instruments or for partial power for radio or radar application. This is my SWAG.
Posted: Thu Apr 30, 2015 5:40 am
by m-11
The 416 volt and 400 cycle rating makes it most likely part of a shop test bench or a power generating piece of equipment.
Posted: Fri May 01, 2015 9:52 am
by Oddjob
What do they call those sets they drag out to fire the jets up... I was possibly thinking something along that line but haven't found much info... All good info guys...
Posted: Fri May 01, 2015 11:08 am
by Carter
Oddjob wrote:What do they call those sets they drag out to fire the jets up... I was possibly thinking something along that line but haven't found much info... All good info guys...
GPU, Ground Power Unit. Those units generate many hundreds of amps and powered by very large Diesel or turbine engines, the unit you have puts out 3.6 amps and is very much to small for starting any kind of aircraft except possibly a model.
http://www.aerospecialties.com/images/t ... CUT_01.jpg
Posted: Fri May 01, 2015 4:21 pm
by w30bob
HI Guys,
I can't tell you the exact application, but it's a motor-generator......not a motor for a generator. I'll let Wiki explain;
In the context of electric power generation and large fixed electrical power systems, a motor–generator consists of an electric motor mechanically coupled to an electric generator (or alternator). The motor runs on the electrical input current while the generator creates the electrical output current, with power flowing between the two machines as a mechanical torque; this provides electrical isolation and some buffering of the power between the two electrical systems. One use of this type of motor–generator is to eliminate spikes and variations in "dirty power" or to provide phase matching between different electrical system; another is to buffer extreme loads on the power system.
later,
