M37 fording kit
Posted: Sun Mar 29, 2015 3:25 am
by Theosaf66
Hi I am Theo from Greece and I am new in the forum,
I have a fully restored (soon I will share some photos of mine) M37B1 and I am looking for a fording kit
anyone???
Theo
Re: M37 fording kit
Posted: Sun Mar 29, 2015 6:01 am
by Elwood
Welcome to the g741 forum!
PM sent.
Re: M37 fording kit
Posted: Thu Apr 02, 2015 3:24 pm
by carolinamv
Does anyone just sell the intake pipe?
Re: M37 fording kit
Posted: Fri Apr 03, 2015 7:18 am
by Elwood
carolinamv wrote:Does anyone just sell the intake pipe?
By "intake pipe" do you mean the rigid pipe that bolts to the bracket on the windshield frame, or the flexible hose the connects the rigid pipe to the air cleaner shroud inside the engine compartment?
One of the vendors (Midwest Military?) sells a new equivalent of the flexible hose, cut to length.
The intake pipe should be relatively easy to fabricate; it's basically just a length of straight, thin-wall pipe with a 90deg elbow at the bottom. I can measure the one I have and send you the dimensions if you want. Do you have the mounting bracket for it?
Re: M37 fording kit
Posted: Fri Apr 03, 2015 5:51 pm
by carolinamv
My truck came with the mounting bracket installed, but no pipe. I need the flex hose and pipe. The exhaust pipe is mounted horizontal on the pass side bed side in it stored position , not in use.
Re: M37 fording kit
Posted: Sun Apr 05, 2015 3:51 am
by Theosaf66
looking at least for the exhaust to placed horizontal for display, I s any one know someone to making it?
