Project M37a4
- SGT
Re: Project M37a4
That is very cool. Great job on that M35 as well. Looks like neat work on that frame extension as well.
Re: Project M37a4
More progress
- m37 26.jpg (71 KiB) Viewed 18811 times
- m37 28.jpg (61.18 KiB) Viewed 18811 times
- m37 29.jpg (55.29 KiB) Viewed 18811 times
Re: Project M37a4
Rough cuts to cabs.
- m37 31.jpg (72.68 KiB) Viewed 18805 times
- m37 30.jpg (68.11 KiB) Viewed 18805 times
Re: Project M37a4
Cool project and great progress. Keep the pictures coming.
- PFC
Re: Project M37a4
Very inspiring.... i had thought about doing an extra-cab lengthening to my M37 but the crew cab looks really good
1952 M37cdn
Re: Project M37a4
M376x6 used to post here and had the dual axles but I don't think he made a crew cab on his-I recall he used a WC63 frame and worked the M37 body panels into that frame-looked very cool.
- Site Admin
Re: Project M37a4
Brian Sage's 6x6 M37 had a longer, custom tray made from 2 M37 trays and the rear frame, suspension and maybe diffs of the vehicle were from a WC series 6x6 plus he had a 360 Cui V8 to get it mobile (very mobile I suspect!!). Brian has not been on here for a long time but you never know, he may chime in....
There was another pic of a dual cab M37 floating about, I think it had the longer type chassis and the tray was a cut down to size affair so I suspect it was made from a maintenance truck or similar.
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Re: Project M37a4
Got the cabs joined up now just need to weld in supports and fill all of the gaps.
- m37 32.jpg (58.19 KiB) Viewed 18713 times
- m37 33.jpg (68.41 KiB) Viewed 18713 times
- Site Admin
Re: Project M37a4
It's looking good, mind you, and I am trying not to offend you but with that much length in added to the chassis it's turning radius will be shitful, maybe shorten the front of the tray a bit and bring those rear wheels back in closer to the back of the second cab or were you planning that anyway?
MM
MM
Re: Project M37a4
I am planning on shorting the frame that's why the rear half is still bolted together. it looks like I may take out 20" of frame. I didn't know how long the extra cab would be until I had it built that's why I made the frame rails extra long. I'm still going to use the full length bed.
- Site Admin
Re: Project M37a4
I can't wait to see the final shape, I guess the pictures and their perspective make the truck look overly long, I am sure you know what you are doing and after your large truck project you have all the kinks ironed out....
Keep this pictures coming
MM
MM
Re: Project M37a4
Going to spend this weekend welding supports in cab and try to get new rear floors in.
- m37 34.jpg (55.28 KiB) Viewed 18632 times
- m37 35.jpg (60.56 KiB) Viewed 18632 times
Re: Project M37a4
Took 17" out of the frame to get wheel base to match up with the stock bed.
- m37 36.jpg (53.87 KiB) Viewed 18612 times
- m37 37.jpg (60.36 KiB) Viewed 18612 times
- m37 38.jpg (67.23 KiB) Viewed 18612 times
- PFC
Re: Project M37a4
Ended up being 36 1/2" added to frame.
- m37 39.jpg (65.82 KiB) Viewed 18604 times
- m37 40.jpg (70.75 KiB) Viewed 18604 times
