T-245 Engine for Sale
Posted: Sat Aug 30, 2014 1:22 pm
I have a T-245 engine for sale. This engine had less than 20 miles on it after a fresh rebuild when it spun a rod bearing. The cylinders still have the hone mark on them. Cylinders are bored .030 over. New valves and guides, new camshaft and bearings, timing chain and both sprockets are new. I have not taken the crankshaft out of this, but its safe to say it will need new rod bearings and the journals turned again. Not sure about the mains. Oil pressure always ran 45+ even with the bad bearing. It also includes a new heavy duty clutch pressure plate and disc. Also includes the engine stand as seen in the photos. No manifolds, distributor or carb.
https://www.dropbox.com/s/r9lcioge39nbp ... 1.JPG?dl=0
https://www.dropbox.com/s/m7k3yep5s79ul ... 2.JPG?dl=0
https://www.dropbox.com/s/4qyy69iggmwro ... 3.JPG?dl=0
Located in Matthews NC. Price $500 OBO Contact me via PM if interested. Thanks.
