Hi Every body,
There is a hole in my Lower Fuel Tank Filler Pipe.
There is any trick to remove this pipe?
I try to unscrew with pipe wrench but nothing appends. I broke pipe.
thanks
M37 CDN 1952
M101CDN2
Montreal(Canada)
M101CDN2
Montreal(Canada)
Re: Lower Fuel Tank Filler Pipe
jj,
Are you talking about the big pipe nipple that's attached to the tank that the hose attaches to for the fuel filler tube? If you are.....that pipe is threaded into the tank.
But after all these years it's gonna be a bear to remove. I'm sure they put some type of sealer on the threads when it was assembled....meaning glue. Probably going to need some heat to get it off........and you know how dangerous that is around an old fuel tank. Be careful. VPW sells NOS nipples for $15, so that's not the problem. Getting your old one out without screwing up the threads in the tank is.
later,
later,
I have my tank out of the truck for repairs, and I was surprised how easily the 1" pipe plug and the fuel petcock spun out. They are quite a bit smaller than the filler pipe though. You might have some luck
Bob,
Yes, it is large 2 1/4 napple. Fortunately, it is replacment tank. It has been stored for more than 10 years without gas. So no problem to heat it.
Jacques
Jacques
M37 CDN 1952
M101CDN2
Montreal(Canada)
M101CDN2
Montreal(Canada)
If you don't do your own soldering I would suggest taking it to a local radiator shop and they can repair no problem!
Hb
Hb
