need spacer between fan and water pump
i need the spacer between the water pump and fan blade on my 1954 m37. where do you get them. thanks dave
Re: need spacer between fan and water pump
I have one somewhere in my piles of unpacked parts boxes, I'll look and get back to you in a day or so if that's ok with you. It will prompt me to put some of junk away.
thanks, dave
Have not found it yet Dave, will continue to look.
Found it.
i found mine under the tool box. thanks dave
10-4
