Radiator question..
Posted: Sat Mar 29, 2014 8:11 pm
by jim lee
Can you pull the radiator without removing the entire front clip? I may be in need of radiator work and really don't want to pull off the front again.
thanks!
-jim lee
Re: Radiator question..
Posted: Sun Mar 30, 2014 1:29 am
by W_A_Watson_II
Yep.
Posted: Sun Mar 30, 2014 12:21 pm
by jim lee
Well, that answers that.
-jim lee
Posted: Sun Mar 30, 2014 4:07 pm
by JimC
You just open the hood, unbolt the radiator, and lift it out the top.
Posted: Sun Apr 06, 2014 10:49 am
by jimmy_stikx
Like Jim said, just undue the hold down bolts and lift straight up.
Posted: Sun Apr 06, 2014 3:00 pm
jim lee wrote:Well, that answers that.
-jim lee
You are right; it is an answer, although not a completely correct one. The fan must be removed from the water pump pulley to provide clearance for the radiator to lift out. The top cover over the radiator top tank must be removed also, and of course the top and bottom hoses must be disconnected.
Posted: Sun Apr 06, 2014 3:33 pm
by W_A_Watson_II
He asked "can you", not how do you.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Posted: Sun Apr 06, 2014 6:47 pm
W_A_Watson_II wrote:He asked "can you", not how do you.
Right, he did. But if he needs to know "can you"; isn't it pretty obvious that he doesn't know "how do you?" Seems to me IF he knew "how you do", then he wouldn't have had a question to begin with. BUT then one would think if he had already been through the procedure of removing a M37 front end at least once prior; he would already know the radiator could be removed without total disassembly of the front clip. I'm wondering if it is him or the rest of us that are confused.
Posted: Sun Apr 06, 2014 8:19 pm
by DJ
He asked a yes or no question. He got a yep,seemed he was satisfied! No confusion here.
Posted: Mon Apr 07, 2014 7:08 pm
by jim lee
I was being lazy. I actually did want the yes/no before going into the work of figuring it out. If it was "no" I'd just pull the front clip again or live with it. If "yes", I'd probably have to deal with it. Seeing it was "yes" the instructions were bonus goodies.
thanks!
-jim lee
