Lock Out Hubs
- CPL
Lock Out Hubs
Has anyone installed lock out hubs (like the ones from Midwest Military) on their M-37. How simple is it? Do I need special tools, like a hub wrench?
- Site Admin
Re: Lock Out Hubs
It's a very easy job Bill, no special tools, just sealant, spanners (or sockets ), a gasket for each side (fun to make your own) and about 20 minutes a side to carry out the swap......
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
- CPL
Re: Lock Out Hubs
Thanks MM, didn't know if I even had to jack it up or even take the wheels off, hee.
Re: Lock Out Hubs
Nope, so simple even a monkey can do itbill monahan wrote:Thanks MM, didn't know if I even had to jack it up or even take the wheels off, hee.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
- Site Admin
Re: Lock Out Hubs
Hey, I resemble that remark......vtdeucedriver wrote:Nope, so simple even a monkey can do itbill monahan wrote:Thanks MM, didn't know if I even had to jack it up or even take the wheels off, hee.
MM
- pwrwagonfire
- SSGT
Re: Lock Out Hubs
I'd use RTV Silicone instead of the paper gaskets, but that's been talked about on here before...
As the others have said, easy easy procedure to do!
Good luck!
Good luck!
- CPL
Re: Lock Out Hubs
Thanks again everyone, think RTV is the way to go.
- Site Admin
Re: Lock Out Hubs
I use a thin gasket (20 to 40 thou) AND sealant to take up any tiny imperfections and make for a snug fit, just my preference though, and after the stub and axle disaster resulting in a trashed axle housing I treat gaskets and their presence with more respect
MM
MM
Re: Lock Out Hubs
One other tip, Make sure the truck is NOT in 4 wheel drive.
Tim
Tim
