Page 1 of 3
New member hello and some questions!
Posted: Tue Jul 17, 2012 2:48 pm
by Tuko
Just stopping in. been reading alot picked a truck up on sunday, work is already in progress! Cant add pic, says "Sorry, the board attachment quota has been reached" There is a pic in the registry though.
Re: New member
Posted: Tue Jul 17, 2012 2:51 pm
by Tuko
Drained oil today, smelled like gas. was able to light it on fire with a torch.
wheres common places to look as to why there is gas in oil?
Re: New member hello and some questions!
Posted: Tue Jul 17, 2012 2:57 pm
by Frank Irons
Check the fuel pump diaphram, if it leaks gas can get into the crankcase.
Frank
Posted: Tue Jul 17, 2012 3:03 pm
by Tuko
Thanks for your reply Frank, does the pump come apart or is there a way to pressure test it on the bench?
Posted: Tue Jul 17, 2012 3:59 pm
by WarrenD
If you have fuel in your oil, it's the diaphragm on the fuel pump. No messing about, remove pump and either rebuild or replace. Then and Now Automotive has the proper rebuild kits (or they will do it). You can also plate off the hole and go to an electric pump (mount it in the rear near the tank). The ethanol in the gas is what is killing the rubber parts, so you'll want to replace everything rubber in your entire fuel line, back to front. This includes the fuel filler and vent lines off the tank. From there, be sure the tank is clean, no rust or varnish; it should probably be drained if it has sat for any length of time.
Posted: Tue Jul 17, 2012 4:37 pm
Welcome aboard Tuko-nice truck, glad to have you with us!
Posted: Tue Jul 17, 2012 5:23 pm
by Tuko
Thank you for the welcome Gary
Warren part of my plan getting it road ready is to flush out the old gas. maybe pull the sending unit and inspect the inside see if its nasty. I emailed then and now for a kit.
I pulled the oil pan today because after i drained out the oil/gas mix i stuck my finger in there and was sludgy on the bottom. going to clean that out and reinstall.
I have the rotors off, pads look good wheel cylinders look bad going to replace all 4.
So my next 2 questions:
1) I read i need a 1100 wix so I ordered one from my local napa they have it for me just have to pick it up. I pulled the old one out and its a NAPA 1010. dosent look like they cross reference I assume they had the wrong one in there?
2) since were talking about gas what do you guys run for octane and do I need to put an additive in the gas? Ive been a diesel guy the last 10 years dont know much about points, coils regulators esp 24 volt but I have been reading up on here!
Posted: Tue Jul 17, 2012 7:14 pm
by Brett
Looks like a nice one to start with. As for pic posting it works better using the img buttons rather than adding an attatchment. do a search its been written about several times.
Brett
Posted: Wed Jul 18, 2012 2:47 am
by WarrenD
Oil filter is the NAPA Gold 1100 or equiv.
I run regular 87 with lots of Lucas ethanol treatment (stabilizer). When you're looking at stabilizers/ethanol treatments, be sure there isn't any more alcohol in the formula, there's way too much in the gas already. Low octane seems to be best, they weren't made to run on top grade fuel to begin with.
As long as you're digging into the brakes, look at the master cylinder too. Sounds like yours has a disc brake conversion, hopefully the Chevy C-30 master cylinder too.
Posted: Wed Jul 18, 2012 3:43 am
by T. Highway
Nice looking truck Tuko.
Posted: Wed Jul 18, 2012 5:23 am
by Tuko
Thanks Bert!
I should have said drums instead of rotors and shoes instead of pads
silly nintendo generation kids
I noticed yesterday For whatever reason my ignition filter is mounted to the firewall but nothing going in or out of it any idea why this might be?
Posted: Wed Jul 18, 2012 6:24 am
by WarrenD
Ignition filter or rectifier? The originals had generator/rectifiers but some folks have had theirs converted to alternators which don't need the rectifier. As you're finding, these trucks have been subject to Bubba mods for many years.
Posted: Wed Jul 18, 2012 6:32 am
by Tuko
warren its this guy thats circled, its there just no wires. This pic isnt mine its one I found on google:
Posted: Wed Jul 18, 2012 8:34 am
by HingsingM37
Welcome to the fold Tuko. Enjoy your M37!
Posted: Wed Jul 18, 2012 12:24 pm
by Tuko
even though its all work at this point im enjoying it alot!
