m37 harness???????
marc8_2
m37 harness???????
Post by marc8_2 »
Would anyone know whats this wiring harness for?
phone pictures 021.JPG (27.07 KiB) Viewed 1620 times
phone pictures 022.JPG (42.21 KiB) Viewed 1620 times
cuz
Re: m37 harness???????
Post by cuz »
Looks like a post 1955 Greek manufactured harness assy. If you have a -34P for the M37 you can check the ORD PN 8338224 in the numerical index.
Corrected typo.
marc8_2
Post by marc8_2 »
whats a -37p????
That might be a typo- the reference is actually to check your "34P" or depot-level Parts manual if you have one-it has 10 times the info found in the "20P" manual.
marc8_2
Post by marc8_2 »
couldn't find anything with the books i have
marc8_2
Post by marc8_2 »
Anybody know what this wiring harness go for before i cut it up to make a harness
I'll check my fed catalog for you, before lunch today.
Well I came up with nuthin', none of the #'s matched anything I have, from 1/4 ton (m-38), early 3/4 ton as well as g-741 thru 10 ton no matches! That doesn't mean it ain't right, does the harness have cannon plugs on either end, are there two separate pieces, front & rear?
BILL L
Post by BILL L »
Best I can find out is it is a control assembly harness made by the General Motors Corp.
marc8_2
Post by marc8_2 »
I can't put up the pictures as there to big.there 2 3female pin connectors, 1 6male pin connector, 1 14 female pin connector, 1 4female connector and 7 douglas single connectors. pictures is from the same harness
Ya i come up with the same thing BILL.
