reserecting an old friend
Posted: Tue Oct 12, 2010 6:19 pm
Hi Gang:
Well.... I've been hiding for a while. I've had my M-37 for 15 years and put over 80,000 miles on her. last spring she laid down and I didn't have the time or money to fix her at the time (had more time than money). Fortunes have changed just enough to allow me to rebuild my engine. I went top drawer this time and did EVERYTHING. I even had the mains line honed. This is only the second engine I've ever built, but I have the books, and went slowly. A shameless plug here: if you don't have the books GET THEM!
Now to the bad news... It won't start. I have fuel at the carb and the ignition timing looks good. By tweeking the distributor I can get her to bark, but it acts like a valve is open. I did a compression check and #2 is low. I am in the process of checking the valve settings and I obviously missed something. at least one of them in the front half is WAY too far open. That means I'll need to check all of them, but that's as far as I got tonight. I also found a post recommending the removal of the front wheel. I'll bet that happens before I'm finished too.
This brings me to my question: some where, I thought it was here, I found a list of which valves could be adjusted at the two top centers. Reffering here to TDC on compression and exhaust. Those two points should get all 12 valves, but I don't remember which ones can be done at which center. I've searched here with all the parameters I could think of and didn't find that info. I DID find a bit of variation in the discussion on cold settings. The range was from .009 to .015. What's right? I think my book says .010 and .013. I think I'd rather have them not open quite so far than to not close all the way when hot.
Any help greatly appreciated
