Gas can fender brackets
52m38
Post by 52m38 »
Does any one have a photo or drawing of the fender brackets to mount the gas can holder ? Thanks.
52 M38
53 CJ3A
53 M37
Oddjob
I'm...
Post by Oddjob »
I'm sure if you were looking to purchase them they could be found at least listed over at VPW...
http://www.vintagepowerwagons.com/pdf/parts/17hood.pdf
4th page half way down on the right side...
If you still want to fabricate them I can take measurements for you... but for 10$ each plus shipping and time making them it might be easier to purchase them if they are in stock over at VPW... Recently I made myself a crank to turn the engine over by hand I made it for 10$ vs. the 35$ plus shipping so it was worth my time... :lol:
If you still want measurements and pictures I'll see what I can do this weekend...
52m38
Jerry can mount brackets
Post by 52m38 »
That would be great if you could get those messurements for me. As I'm a hands on kind a guy. I could buy them. But I know I could make them. Thanks. Brett
P.S. sorry for the late reply. I was out of town.
52 M38
53 CJ3A
53 M37
Oddjob
I'll...
Post by Oddjob »
I'll work on it and make a PDF file for you... with all the spec's...
52m38
Post by 52m38 »
Thanks. That would be great.
52 M38
53 CJ3A
53 M37
mikkelborg
Post by mikkelborg »
Could you post the PDF or send a copy to me when you are done please? I need to fabricate the same brackets.
Thank you,
Collin
Oddjob
Yeah...
Post by Oddjob »
Yeah no problem...
May 9th brackets removed... Should have measurements Monday...
Oddjob
It's
Post by Oddjob »
It's done... Thought I could do an attachment but doesn't look like it so if you need it PM me your email and I'll send it off... All dimensions are as close as I could get them... Little heat and a good steel brake and you should be good... :D
52m38
Post by 52m38 »
Oddjob. PM'd you. Thanks again
52 M38
53 CJ3A
53 M37
Oddjob
Re: Gas can fender brackets
Post by Oddjob »
Attached is the file if anyone else wants it... Big thanks to Robi for getting us set up to attach things like PDF's...
Brian
Oddjob
M37 gas can fender brackets-1.pdf
Drawing showing where bends for the three brackets that extend to the fenders...
(13.63 KiB) Downloaded 193 times
