90# gear lube.
90# gear lube.
IS there any special gear lube I need to use in my differentials? Also how much will I need?
Gerry
53 M37
53 M37
Each gets 6 pints.
80-90 gear lube is a better choice, flows better on a cold start up. Making a premium brand choice is also a smart move. Many cheapo brands are out there now. With bearings to build a diff now over $600, you want to invest in a good quality oil that will do the best job.
My preference would be Royal Purple Synthetic MaxGear, available through NAPA or Synergyn 80-90 gear lube, available from www.SynergynRacing.comGerry wrote:Charles,
Any brands you recommend?
Hydrotex is a very good brand also.
Any of these have a strong additive package with ingredients that causes the oil to adhere tenaciously to gears and bearings, far superior lubricants to the general off the shelf brands.
Charles,MSeriesRebuild wrote:My preference would be Royal Purple Synthetic MaxGear, available through NAPA or Synergyn 80-90 gear lube, available from www.SynergynRacing.comGerry wrote:Charles,
I assume that would also be good to use in the gear boxes of my '42 jeep?
Greencom
- PFC
