Where'd the oil go?
- SSGT
Where'd the oil go?
Hello long tooth tire changers, and today's question is about the oil in the front axle case. While topping off my M37 gear boxes I noticed how easy it was to add just a few ounces , first, to the transmiossion, then the transfer case; why, I didn't even have to refill my piston type oil charger more than once! Ah, here's the front axle case. I remembered to add a short extension to my ratchet so the tool end fits deep into the sqaure head jam nut. Out it comes, next, insert the charger hose, and squeeze...swish, swish and the tube all empties . Well, I'll just recharge my tube. Can't take much more to "top" it off, right? Swiiish. The hole tube empties ! And another tube ! DRAT, I wound up filling the case from empty ! But i don't see any oil stains on my driveway, something a particular family member would certainly have brought to my attention. And I don't see any oil at my drive shaft seal, either.So where did all that oil go?
1952 M37 W/W
HELLO FRIEND. I AM AFRAID IT IS NO MYSTERY BEHIND THE DISAPEARING OF THE OIL. FIRST OF ALL, HOW MUCH OIL DID YOU EXPECT TO FIND IN THERE TO BEGIN WITH? IF YOU EXPECTED IT TO BE FULL SINCE THE LAST TIME YOU TOPPED IT OFF, THEN I WOULD BELIEVE YOUR LEAK IS AT YOUR STEEIRING KNUKLES. AND CHANCES ARE THAT IT LEAKS A LITTLE AT A TIME WHEN YOU TURN THE STEERING, NOT WHEN THE VEHICLE IS STILL, HENSE NO OIL STAINS ON YOUR DRIVEWAY. JUST MY TWO CENTS. GOOD LUCK WITH THAT
- SSGT
- SSGT
