PTO Winch Questions
Posted: Thu Apr 23, 2009 2:40 am
by m37_power
I have few questions about the factory Braden PTO winch. What does it take to shear the pin in the winch? I guess i am worried that when i take it off road that if i get stuck and try to use my winch, its just going to shear the pin. I ride with a bunch of guys in Newer Jeeps that i don't see how could pull the dodge out. What is your opinions on this matter? Ive read mixed things while searching on this and that's why I decided to post up and ask. How much can the winch handle? If I am stuck on a hill will it pull me up or just shear the pin? Any help is greatly appreciated.
Posted: Thu Apr 23, 2009 5:06 am
by Tom @ Snake River
The best thing you can do is get "geared up" with winch accessories. Get a good snatch block and get used to useing it, even if you do not think the load needs it.
A good length of chain, and few straps, and even a Pull Pal anchor comes in darn handy.
As far as shear pins, make a bunch up out of 5/16" redi-rod.
Remember if you are out with a bunch of Jeeps, you are the "BIG DADDY", your the one that gets things done. "GIT R DONE"
Posted: Thu Apr 23, 2009 5:26 am
by m37_power
lol....sounds great to me. ive already bought a couple high lift jacks, straps, chains, snatch blocks and im learning all about reducing the actual load by using pulleys. and yes.....the dodge will be much bigger then most of the jeeps that i will be out with. thanks for your response.
Posted: Thu Apr 23, 2009 7:51 am
by monkeymissile
I think the winch is rated for 7000 or 8000lbs, enough to pull you out in most cases
Posted: Thu Apr 23, 2009 11:37 am
And using a snatch block gives you 2 to 1 winch capacity; using two snatch blocks gives you 3 to 1, enough to pull most anything, as long as you are sufficiently anchored.
Posted: Fri Apr 24, 2009 5:14 am
by Lifer
I'm kinda surprised, actually, at the number of people who don't understand the use of snatch blocks. We learned all about pulleys and how they affect the pull:load ratio way back in junior high science class. I graduated from junior high way back in 1958, though, so maybe they don't teach rudimentary mechanical theory in school any more??
Posted: Fri Apr 24, 2009 5:48 am
Very true, Lifer! I wonder if anything at all is being taught in some schools today, much like your "turn the key and aim the car..." post from some time ago where the kids do exactly that to get from point A to B.
Funny, I just picked up an 8-ton WWII snatch block at the swap meet last Friday and it's a heavy sucker (but nothing compared to the 90-ton block I used on my M88A1 back in my Army days....)
Posted: Fri Apr 24, 2009 10:30 am
by TOM R
we carry at least 2 snatch blocks, i get em used at the place i buy my steel from also some old cargo rigging straps to save the trees
