NV4500 Slip Yoke and Bell Housing Questions
SierraM37
Post by SierraM37 »
My M already had a 318 swap, so now I'm mating an NV4500 up to it. It's the 2WD Dodge version with a 30 spline output shaft. Can I just buy any 30 spline slip yoke and mate it up to the NP200 flange? Is there a specific U joint I have to make sure it is compatible with?
For the Bell housing and clutch setup, I got a factory 318 BH that mates up to the NV4500. Is that the correct one or do I need some kind of adapter? What about the hydraulic clutch setup - What parts are needed from flywheel to clutch plate to pilot bushing to slave and master clutch cylinders?
Thanks in advance gang. Finally gettin' some good rain and snow out here in Northern California. Wish it would bury the state capital and all the slimy inhabitants!
Todd
'52 M37 W/W
'52 M37 WOW
'01 Dodge Durango
'07 Jeep Rubicon (JK)
