Ok I have a hydraulic clutch on my 318 that I put in my m37
- SGT
Ok I have a hydraulic clutch on my 318 that I put in my m37 and need the master cylinder. I know how to hook it up my question is this, does it matter what m/s I use? If not what did you use?
- W_A_Watson_II
bubba_got_you,
I started with a 3/4" MC and switched to a 1" to make sure I had enough throw, and it felt like the 3/4" wasn't enough.
http://m37.wawii.com/
Assuming you used a NP435, what slave cylinder manufacturer and part # did you use? I'm having trouble finding the proper part. Thanks.
As far as m/c for the clutch - most folks use a 3/4" bore m/c from what I saw on the web. Any old single line brake or clutch m/c with at least 3/4" bore should be good. (I might re-use the original M37 m/c for this). No matter which m/c is used, the pushrod length may need adjusted to get good clutch release and pedal feel.
- W_A_Watson_II
Wilwood High-Volume aluminum master cylinder 260-6766
http://www.wilwood.com/Products/006-Mas ... /index.asp
