I'm hopeless, Valve inspection plate question
KenInGA
Post by KenInGA »
Any tips for putting the screws back in the valve covers while the engine is in the truck? I do have the inside fender plate off.
Or should I just fiddle around with it until I get it.
Yours in rebuilding [230s],
Ken
'62 M37B1- It runs AND stops!
Re: I'm hopeless, Valve inspection plate question
KenInGA wrote:Any tips for putting the screws back in the valve covers while the engine is in the truck? I do have the inside fender plate off.
Ken
I don't understand your problem, never had issues with this before.
rixm37
Post by rixm37 »
You can feel for it . It takes a little time .
Don't need to remove fender well.
Then you can put a 13/16 shallow 12pt socket over the finger hold and gently tighten.
Don't forget to put new gaskets under the screws as well at the covers.
Felpro still available at local auto part stores.
Wayne64
Post by Wayne64 »
Don't know if this applies to the 230 but I use headless studs all the time on reassemblies of all manner of things so everything lines up.
Wayne64 wrote:Don't know if this applies to the 230 but I use headless studs all the time on reassemblies of all manner of things so everything lines up.
Headless studs work great in this application, slightly in the way when doing valve adjustments however not bad.
KenInGA
Post by KenInGA »
Thanks for the advice rixm37. I had forgotten about the gaskets for the screws. I like the idea of headless studs too, I may try those.
I had already taken the whole fender and related off of that side for accessibility to various other things. It's nice, you have a lot of room to maneuver. Makes things easier for doing a lot of things when you take the fenders off.
jbxx
Post by jbxx »
Part #'s for the valve covers and the screws?
Tnx.
J.B.
topellis
Ken
Post by topellis »
Ken Where are you in North GA?? I am in Yorkville, between Rockmart and Dallas.
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
jbxx
Post by jbxx »
I meant to say, or ask for: part #'s for GASKETS for valve covers and screws. Sorry.
J.B.
KenInGA
Re: Ken
Post by KenInGA »
topellis wrote:Ken Where are you in North GA?? I am in Yorkville, between Rockmart and Dallas.
Mark
I'm in Alpharetta, about 10 miles S. of Cumming, straight down Highway 9
jbxx wrote:I meant to say, or ask for: part #'s for GASKETS for valve covers and screws. Sorry.
J.B.
NAPA VS36054 is the push rod cover set, includes screw gaskets.
jbxx
Post by jbxx »
Tnx once again Charles!
J.B.
KenInGA
Post by KenInGA »
Thanks here, Charles, as well. I was rooting around and my full engine gasket set is lacking these gaskets.
