picture of wiring harness req
Posted: Thu Oct 02, 2008 5:19 am
by SydneyM37
Hi,
i have run my harness down the right hand side. but my concerns are when it comes to the bend at the rear.
Does the loom go in the hole or does it raise above the chassis.
(if this question is a bit weird, just a photo of the rear/right corner will be great.
cheers
Bruce
Posted: Thu Oct 02, 2008 5:38 am
by Lifer
Not having my truck here to look at, I can't say for sure. I will say, though, that any time wires are run through a hole in a metal part, there will be a problem with chafing unless a rubber grommet is installed first.
Posted: Thu Oct 02, 2008 6:37 am
by refit1701
If you're talking about the rearmost crossmember, it goes on top. There should be two "U" shaped clips screwed to the frame to hold the connectors.
Harness
Posted: Thu Oct 02, 2008 12:00 pm
by SydneyM37
Thanks guys,
I was just concerned at the point from where it travelled down the side, to the exact spot where it rose up onto the rear crossmember.
It looks like a place where the loom can be damaged,
Bruce
Posted: Thu Oct 02, 2008 12:33 pm
by refit1701
You can see the harness in the left corner. Perhaps this helps?
thanks
Posted: Thu Oct 02, 2008 9:06 pm
by SydneyM37
Thanks John,
That was the money shot, thats how i installed it, i just did a bit of reinforcing right on that bend, so it doesn't rub through.
Cheers
Bruce
