I managed to save about a dozen, but so far had little or no luck welding them back in place.
Does any body no of a source for now weld-nuts?
Larry Sage, You got your ears on?
Bed Nuts/Captive Bolts
Weld Nuts
McMaster-Carr has square weld nuts 1/4 inch up to 5/8 in NC and NF also has hex, tab, and other styles as well
http://www.mcmaster.com/
5/16 NF are $8.12 for 50
Paul f
Thanks Paul
For the heads up, did you use these, they look perfect?
Thanks Again,
Thanks Again,
