How tall is the softtop?
Posted: Mon Aug 04, 2025 2:05 pm
by Rdinatal
I've measured, researched and came up with multiple heights. So, what is the height of the softtop bow?
My 'calibrated eyeballing' says just under 7ft.
Re: How tall is the softtop?
Posted: Tue Aug 05, 2025 4:55 am
by WarrenD
Are you looking for a vertical clearance measurement from the ground? If so, which tires? I can measure mine, I have stock NDTs. I can tell you that it fits in a standard residential garage with room to spare.
Posted: Tue Aug 05, 2025 5:01 am
by WarrenD
Mine looks to be a tick more than 82", so I'd go with 82-1/2" clear.
Posted: Tue Aug 05, 2025 8:05 am
by just me
My cab bow is 83" and the cargo bow is 92" at the highest point.
Posted: Tue Aug 05, 2025 11:49 am
by Rdinatal
WarrenD wrote: ↑Tue Aug 05, 2025 4:55 am
Standard 9x16 tires. Measuring from the ground to tallest pont on the cab. I have 82".
Posted: Tue Aug 05, 2025 11:50 am
by Rdinatal
WarrenD wrote: ↑Tue Aug 05, 2025 5:01 am
I'm thinking >84" door opening is good.
Changing garage location so I don't have to take the bikini top off/on every time.
Posted: Tue Aug 05, 2025 1:26 pm
by WarrenD
Always better to have 1" too much clearance than 1/8" too little!!!
Posted: Wed Aug 06, 2025 3:06 am
With my 900x16s and 50 %tread I'm 71 at the back cab bow. I may need to check again based on the other responses.
