Page 5 of 7
Re: 1963 M37B1 and introduction
Posted: Thu Jan 28, 2021 6:14 pm
by Explorer0863
Posted: Thu Jan 28, 2021 6:20 pm
by Explorer0863
Posted: Fri Jan 29, 2021 5:19 am
by NAM VET
I have learned to de-rust and prime and paint small and larger projects on my own truck, but beyond that, like metal work, is beyond my equipment and especially my meager ability. There is something deeply satisfying in making some tool or object look good once again. Yours does. Eventually, you will spin and fire your motor for the first time. Nice work, and good pics too. Keep it up.
Posted: Sun Jan 31, 2021 9:09 am
by Explorer0863
NAM VET wrote:I have learned to de-rust and prime and paint small and larger projects on my own truck, but beyond that, like metal work, is beyond my equipment and especially my meager ability. There is something deeply satisfying in making some tool or object look good once again. Yours does. Eventually, you will spin and fire your motor for the first time. Nice work, and good pics too. Keep it up.
You are so right! Thank you.
Posted: Sun Jan 31, 2021 9:25 am
by Explorer0863
After a long time letting the red oxide cure, I applied 3 coats of paintable under body protection. I think this chassis will last another 57 years.
I made a decision on the paint color. After many, many months of researching and pondering colors and options, I decided to paint it "Early WWII Lusterless Olive Drab", code 33070.
- IMG_7254.JPG (158.89 KiB) Viewed 3415 times
- IMG_7255.JPG (177.93 KiB) Viewed 3415 times
Posted: Sun Jan 31, 2021 9:34 am
by Explorer0863
Thanks to my stepson and great neighbors, I removed the cab. Due to space limitations, I moved it to the rear of the chassis where the bed is supposed to be. Now I'll be able to work on some required patches. As you can see the previous owner "restoration" was done without removing the bed.
Once I'm done with it, I'll flip it and start working on the floor. The interior part of the floor was previously fix and it's good, but underneath the floor the job done was very poor and will require some cutting and welding. But this time, it will done right and time well spent.
- IMG_7376.JPG (220.96 KiB) Viewed 3414 times
- IMG_7377.JPG (200.5 KiB) Viewed 3414 times
- IMG_7374.JPG (164.19 KiB) Viewed 3414 times
Posted: Sun Jan 31, 2021 9:39 am
by Explorer0863
Posted: Sun Jan 31, 2021 1:08 pm
by m-37Bruce
Vast improvement, you are moving right along!
Posted: Sun Jan 31, 2021 1:36 pm
by RCrombie
Hey look at that, your power to weight ratio just went up!
I found on my truck that often the dirt accumulated inside crossmembers and cavities to the point where the bolts that protrude into them had rusted entirely away. That, or the captured nuts were wasted down to nothing from the retained moisture. Oddly enough the sheet metal was usually fine, but the fasteners were all junk.
I always get a kick out of before and after pictures with cleaning parts.
Posted: Sun Jan 31, 2021 4:30 pm
by Explorer0863
m-37Bruce wrote:Vast improvement, you are moving right along!
Yes, this week was very productive. Thanks!
Posted: Sun Jan 31, 2021 4:33 pm
by Explorer0863
RCrombie wrote:Hey look at that, your power to weight ratio just went up!
LOL! Big time!
Good call. I will be checking every bolt and nut before putting it back together. Thanks!
Posted: Sun Jan 31, 2021 11:54 pm
Looks great Tony-well done!
Posted: Mon Feb 01, 2021 7:08 pm
by Explorer0863
Cal_Gary wrote:Looks great Tony-well done!
Thanks Gary! Hope all is well.
Posted: Wed Feb 03, 2021 10:06 pm
Still isolating and masking up-thanks for asking!
Posted: Sun Feb 07, 2021 5:25 pm
by Explorer0863
