The base plate at the front of the seat... Not bad for just a bench vise and a hammer, eh?
Mating it up to the doghouse cover... Notice I got the other side of the doghouse welded in, and the top of the doghouse welded (relatively) smooth. It'll need a thin skin of body filler or better yet, lead, to fill it in and make it perfectly smooth.
The T case in its final place, it fits GREAT! I need to build a mount for it...
This is what I have in mind. It'll bolt to the inside of the frame channels on each side...
the seat plate all bent up, and the flange folded up to spot weld to the seat base. Again, all hand formed...
Test fitting in the truck:
Floorpan all tacked together. I know, my welding leaves somthing to be desired... thank god they make sanding flapper wheels!
I'll cut all the original metal out of the underside once I get it welded up to prevent dirt from filling it and rusting it out...
Test fit in the truck:
Still need to patch that small hole... no big deal:
