Parley vou via Google Translate-copy the French and paste it in:
https://translate.google.com/
hello of France
Re: hello of France
Re: hello of France
Hello,
a lot of work on the M37. I have a problem with the carburetor. Should I put the pipes but I have not the carburetor diagram. I lost my photos. Someone there any carburetor pipes to engine Photos
thank you very much
merci beaucoup
thank you very much
merci beaucoup
Re: hello of France
From TM 9-2320-212-20 Organization Maintenance Manual for Truck, Cargo: 3/4 Ton 4x4 M37 and M37B1
From TM 9-1840A Ordnance Maintenance Engine (Dodge Model T-245) and Clutch (Borg & Beck Model 11828)
Re: hello of France
hi,
I have a problem with the engines. I need some important information.
I hope my translation is good.
A big thank you for your help
French yoann of Normandy
engine : 230 ???
crankshaft tightening pattern
Con Rod Assy tightening pattern
size standard piston
size bore piston
size standad crankshaft
:size bore Crankshaft
engine : 230 ???
size bore piston
Re: hello of France
Ces informations devraient tous être ici: http://www.imfmotorpool.com/files/TM9-1 ... clutch.pdfyoann44 wrote:hi,
engine : 230 ???
size bore piston
Les écrous de bielle et les principaux boulons de chapeau de palier ne disposent pas d'une séquence de serrage spécifique. (The connecting rod nuts and the main bearing cap bolts do not have a specific tightening sequence.)
Re: hello of France
Thank you very much has you I am going to be able to look at the book. Have to try to translate now.
Thank you thank you
Thank you thank you
Re: hello of France
Glad to help.
Cylinder bore standard size = 3.250 inches
Crankshaft main bearing journals standard = 2.500 inches
Re: hello of France
Thank you for your help
Re: hello of France
hello,
I looking for a crankshaft and Crankshaft Bearing for engine t245 to send in france.
Store usa?
Store usa?
