New Denman NDTs on the truck!
Carter,
The new rubber looks sweet 8)
Nickathome
Spare
Post by Nickathome »
My truck is a B1, and although I would like to install the spare tire carrier on the door frame, I will be just as happy to retrofit an inside the bed carrier in lieu of. Now if I can find either that won't rape my wallet just to purchase I'll be doing something.
Nickathome
Spare carrier.
I like the bumper mounted spare carrier. One way to rid oneself of the need to open the spare carrier before climbing in.
cuz
Post by cuz »
Nobody can see in with a canvas tonneau cover - so why not just lay the tire on the bed floor like 60 million other truck owners?
I'm talking a driver and I am very tired of moving the tire every time I have stuff to slide up in the bed. Even with a tonneau cover I carry several tool boxes and parts containers.
Master Yota
Post by Master Yota »
I see.
Why not consider a swing out carrier (a-la-Jeep) to mount either from one of the rear bumperette's, or perhaps if you have a reciever hitch, from an insert. Its not difficult to build a pivot with an arm, and 99% of the motoring public wouldn't know if it was factory or not. A rear bumper mounted spare would be more visually appealing than one hanging off the front bumper like the Fords of the 70's...
The pocket in the tonneau cover isn't a bad idea either...
Master Yota
Carter,
Could you do me a favor by taking two measurments for me? I need a distance from the center of the rear fender lip to the ground, and one from the front frame rail behind the bumper to the ground.
I forgot to take them before I tore my M apart with the swap, and now I have no baseline for the new suspension to see how much lift I've gained.
I figured with the new rubber on your M its as close to factory height as I can get.
Thanks, Ray
