No real serious work done tonight, just some brainstorming and fit up testing... Have some interesting results, thats for sure!
I ended up ordering my Mopar Performance cast valve covers, as well as a nice Comp Cams double roller timing set. I also ordered a fuel pmp block off plate, and the accessory kit for the valve covers.
Anyway, on to the good stuff tonight...
Was looking at the factory manifolds... and something occured to me...
the only issue is that I can't get to the spark plug holes...
However, if I make spacer blocks 2" thick, I can get in to the plugs no problem. The total width of the engine with the spacer blocks, outside of one manifold, to outside of the other will be 30"... same as the frame, and pretty close to what my 360 measured with it's goofy mounts that I made. Near as I can tell, using the stock 1977 cross member will mount it approximately 1-2" lower in the frame, which will be perfect... The plugs will be almost laying on top of the frame.
It's been a while since I pulled the Holset and Supercharger out of the closet... so, here they are...
I also sat down and did some math and have some semi-bad news...
P1XV1=P2XV2
So, lets assume that, I want around 6 PSIG, or 20 PSIA of boost from the blower. This is P2. This should make the intake the highest pressure point in the engine, and, make that porting work that I did very, very effective at creating power. Now, let's take the turbos out of the equation to simplify things a bit. So, P1 is the atmospheric pressure, which would be 0 PSIG, or 14PSIA, and V1 is how much volume the blower needs to move, and what we want to figure out...
Now, V2 is the engine displacement, and, the 400 is a 6.55L engine, and I'm going to assume a 6K RPM redline. However, to fill all cylinders at least once, the engine has to make 2 revs, since its a 4 stroke, so in reality, we're only turning 3K... at least how the blower sees it.
Now we have:
P1= 14 PSIA
P2= 20 PSIA
V1= What we want to know
V2= 6.55L per 2 revs, X 3000RPM = 19,650
so, we put this back into the equation, solve for V1, and we get
393,000...
Now, I know the blower moves 1.7L per rev, and I know it has a Max RPM of 14,000.
So, putting that together, for volume I get a max from the blower of only:
23,800 L/Min.
Now, times that by the pressure, and we come up with:
333,200
So, were short, which means the blower is too small for a 6K RPM rev limit. Now, what we can do, is put the max of the blower in, and solve for our engine speed, if we do that, we get:
14X1.7X14,000=20X6.55XS Where S= max RPM of the motor.
Solve for S, and we get:
2563!!!!
Ah, but, remember, it's 2X, because it's a 4 stroke. Taking that into account, we have about a 5200 RPM redline before the blower begins to loose boost. Now, that doesnt mean we cant spin it to 6K, that just means the blower looses it's ability to compress air past 5200 Crank RPM.
However, one more caveat. We assumed that at 5200 RPM, the blower will be giving it all she's got, so, we are limited to 5200 RPM.
Now, the pulley diameter on the blower is 3". and, we have a drive ratio of:
14000/5000, which is: 2.8:1
2.8:1 is a relatively high belt ratio, but, is still within operational specs for serpetine systems, so, we are good. We are limited to 5K RPM, which, isn't necessarily a bad thing.
This means that I have to find a 6 groove serp pully thats, *gasp* 8.4" in diameter!!!
Mocked up in that position, the carb is almost as tall as the blower... should be plenty of hood clearance...
Went ahead and cut the manifold, and mounted it out about 1.5" from teh head, as far out on the factory studs as I could get it... I'll go to the hardware store tomorrow and get some longer bolts so I can mock it up exactly...
Hmmm, turbo is WAY to high... the flange doesnt fit the manifold very well either...
I'm fully aware that welding Mild cold rolled to cast is very difficult, so, I'll be taking it in and getting a local shop to nickel/Iron braze the 1" thick turbo flange on...
Made a second cut, this time at an angle, and about 1.5" lower...
almost 1/2" of iron to play with... that will hold the heat in well.
Template I made of the turbo flange...
Spark plugs will definitey be needing a heat shield...
Lets see how they look together...
Notice how close I can tuck the turbo outlet for the compressor in to the valve cover... the piping from turbo to supercharger is going to be insanely short.
Going to come off both sides and come into the back of the charger. Am going to toss that silly black plastic backing plate and replace it with a steel one with pipes coming in from each side at about 45*. That should just sneak past the carb. In the pic below, I plan on adding a water to air intercooler, where the carb hat will face to the passenger's side head, and the intercooler will be a simple in off the supercharger discharge seen there, make a 90* bend into the core, through the core, then a 90* bend into the carb hat. Again, nice and short plumbing... might not even need to use tubing, might be able to make it all fit with silicone couplers.
Very, Very tight...
