Timing pointer on 230 flat head six engine missing
Re: Timing pointer on 230 flat head six engine missing
with the clutch disengaged, I am able to turn my engine's crank by just using the fan blade. My truck has the four belt pulley, so maybe that is why it was easy. Plus, I had all the plugs removed when I was checking some things. Then too, by looking at the fan blades, I was sure I was turning the engine in the normal rotation to be sure the timing chain was tight.
Had a really good "shoot" Sat with my IDPA club. We are supposed to shoot something called a "classifier" once year, it determines a shooter's classification in matches. Shooting my H&K VP9, I was just "on", even at the 20 yard line, leaning out from cover. Was tenth out of about 50 talented shooters, and moved up one class. Now, to work on making the next one, Expert. I have been doing IDPA for about 5 or 6 years now, and have made so many good friends in our small local club.
I talk to a lot of guys, who just don't have many or even any "good friends", and feel that they are missing out on so much comraderie. I reload my own ammo, that way I can shoot almost daily at a nearby indoor range. Practice makes (nearly) perfect. Life is good. Recently completed a two year course of Chemo, and now to wait and see what is next. All the best to all of you.....
Hal, aka NAM VET
now for picture of a nifty armored car, from when I was in Desert Storm.
[url=https://postimg.org/image/d0gywp1f ... .jpg[/img][/url]
You may as well stop being concerned about the missing pointer issue. With 100 PSI compression readings across all 6 cylinders, it is seriously time to start thinking about a complete rebuild; at which time the engine will be disassembled making replacement of the pointer (or replacement of the cover) a much less intense issue.
mdainsd
Post by mdainsd »
In the tune up adaptor kit is the tool that goes into the inspection plug on number 6. It is there for a reason.
Mine is missing the pointer too, but never used it anyway. I set my timing with a vacuum gauge. Adjust idle timing for highest vacuum. Worked for me for years.
mdainsd wrote:In the tune up adaptor kit is the tool that goes into the inspection plug on number 6. It is there for a reason.
By "tune up adapter kit", do you mean the kit of electrical adapters for checking the generator, regulator, etc.?
I ask because Miller also made a top dead center tool (No. C-435) that screwed into the 1/4NPT timing plug hole over the No. 6 cylinder.
mdainsd
Post by mdainsd »
Yep.
"Adaptor Set, Engine Electrical Test"
NSN-4916-00-348-7600
Bottom right of the box in its own little holder.
Do you mean item 5 in this drawing (from TM 9-4910-607-14&P Adapter Set, Engine, Electric Test, Sun Electric Corp., 4910-00-348-7600)?
Because I think that's just the distributor primary adapter, which screws into the port in the distributor cover above the coil:
Here's the Miller C-435 tool for measuring TDC in No. 6 cylinder that I was thinking of:
