Hi Justin,
Grinding .060 off the head is easy enough, you also suggest cutting in a second exhaust outlet on the exhaust manifold? Would that make noticeable difference? Does the stock manifold create enough restriction to rob power? I have a steel manifold that I built when i first got the truck, Maybe i should wack another hole in it.
The ring gears in my differentials are stock, I'm not sure what the stock gear ratio is.
Thanks for the reply.
Restomod m37 video
dmowrey3@comcast.net
- PFC
Re: Restomod m37 video
Great job Justin .... enjoyed the video !
