Re: Truck dies when hot and then runs later
Posted: Mon Apr 17, 2017 11:39 am
When I took the cap off of my Military distributor as part of my rebuild, my flat spring on top of the rotor was also broken, although since the truck was running, i guess the graphite nib on the top of the cap was making sufficient contact for it to distribute the spark. Long ago, when i frequently tuned my English sports cars and my VW, I never had such a problem. My pistons and rings and bearings and such are coming tomorrow, so the machine ship can begin to bore this and that, balance things, and get it back to me for my own wrenching. Completed the wiring for my Hella horn today, I did it the easy way, running the wires with a fuse to a dash mounted hold-up-on toggle switch. Then drained and refilled the transfer case and both diffs, using Redline 75-90 synthetic, is appropriate for hypoid gears. No nuts and bolts and gears drained out via the drain plugs.
I would prefer to run my horn wires from the steering wheel button down the shaft, but first I have to hear how difficult it is to pull off the button. I have all new OEM parts for the proper horn wiring.
Any advice on pulling off the horn button? I have read prior posts on this forum about doing it.
all the best....
At first in Desert Storm, when the medical choppers would bring in our patients, we had a big problem with sand blown up by rotors, bad for everybody, and especially the Blackhawk engines. So, we promptly had a solution......
like soaking our heli-pad with diesel fuel, no EPA in the desert.
all the best....
