Clutch slipping....
Re: Clutch slipping....
Outstanding job, John! So, for the group, how far off were those fingers, and what tools did you use to adjust them?
refit1701
Post by refit1701 »
The adjusting nuts are accessible without pulling the transmission and are 9/16". We figured out the height of the fingers from the flywheel with the disc in place (each truck will vary some) and used a dowel to measure the height. Then the nuts were staked as per the manual.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
Thanks John!
Tom P
Post by Tom P »
Where did that pressure plate come from?
I would hate to buy and install a clutch assembly only to find it's
Out of Spec.
Was it new or rebuilt?
Thanks Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
refit1701
Post by refit1701 »
Actually, it was the one on the engine when I bought it. I remember when we originally installed the re-lined clutch and had to add spacers that we thought the friction material was thicker than stock. It's possible that the pressure plate was adjusted wrong to begin with and we never thought about checking it. I bought a new one, which we didn't use, which seems to need adjusting too. That is when I need to use it. Many variables involved.
-John
S-89 Comm box
