Hey CUZ!
I am impressed!! I tried a couple of different ways and finally just went to the photo album!! Thanks for the help my Friend!!
Water pump question?
- Tim Powell
- MSGT
Re: Water pump question?
- m37jarhead
Steve:
How about getting your original water pump rebuilt? It's so simple you might be able to do it yourself
and then you'll have an "original" pump with grease cup back in service. Wouldn't hurt to save the
"new" pump for a rainy day.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Tim,
Watch for a PM on how to post the photos. My good friend Brett talked me through it a while back. If you have any questions just get back to me.
Phillip
Phillip
M37jarhead, That was my original intention, but when I was taking the original apart I broke what looks like a steel thrust washer between the nose bushing and where the shaft goes through the housing by the seal. As that is not in the kit I would need to find one or try to replicate it. So for now I had a spacer made and will use that with the new water pump until I get the correct parts to fix the original one.
Steve
Steve
