1955 m 37 cannadian build, lots of restoration pictures
- HingsingM37
Great pictures. Welcome aboard. Looks like a couple of decent rigs. Whats with the trees on the bedless truck? Were they growing up through it or was somebody being creative?
powerwagontim
believe it or not the wood post on the bed less one where there to hold wood, the old fellow who owned it for the last 30 year used it only as a skidder/porter, he said he was putting a cord of hard wood on the back of the frame and he was twitching 4 big lug of mapple at the same time with that truck, just proove how sturdy they are and lucky for me it has never seen the road and salt so the whole truck is in pretty good shape minus a few dent...lol
allrigth , today i have had the cab off and started cleaning and removing stuff from the frame , i also started to cut off the wood carrying gizmo that where welded to the frame with the plasma cutter, did i tell everyone how much that tool is fun to use , ge i like my plasma cutter...lol
any how here are the pics, enjoy!!
cab less frame started to be cleaned
wood shit started to plasma off
the cab is in very nice shape found just a few hole to fix
Paul, It looks like you are making great progress on the truck.
You may be working too fast because the snow has really melted since your first post 3 days ago
did more work on the m truck yesterday and this morning, pretty close to start restoring the frame , gt some sanding disc and the primer and paint today, gee that stuff is becoming expensive, oh well if i want a good job i have to get the good stuff i guess
front frame view
rear frame view
some one did a poor welding job on a crack
another crak by the stearing box mount
transfert case crossmember had a hard life
power train awaiting restoration
striped the rear of the frame this morning
mask , tack cloth and filter for the paint
primer with etching primer in it
the paint formula from sherwin william
paint hardener and reducer, note the color, it is exactly the same as the paint on my nos gas cap, the rigth olive drab, cool
pre marked mixing cup for the paint wich goes 8-4-1, and the primer is 1 to 1
now it started raining so i stalled for the day
front frame view
rear frame view
nice day today had some more work done and started restoring the frame
ouf hard labor but it will be worth it, i found some marking stamped in the frame including a serial number , but the number is to faint to show on the camera, you can also see all kind of tool marks on the frame proving it was bended cold or pressed
any how here are the pics enjoy!
crack ready to be welded
crak welded
where is the crack?
other crack fixing
original dodge black paint showing under the drab
1/3 sanded down
marking stamped in frame
axles waiting restoration
crak welded
where is the crack?
other crack fixing
1/3 sanded down
Master Yota
- MSGT
same old today boring stuff, used some chemical aircraft paint stripper to remove the old paint from the frame in order to cut dow on sanding , lot of scraping nothing to take picture of, sarted taking the rear axle appart and destroyed the pinion bearing trying to save the oil seal, darn it , there was a nut holding he bearing in, lol oh well live and learn , will post pic when interesting stuff stats happening
paul
paul
Master Yota
- MSGT
well today the frame of the truck got the finish sand blast and sanding and a coat of etching primer, i am happy, restoration is starting since i got the first coat of paint on its foundation, yeaah baby, anyhow here are the pics
enjoy
frame all shiny and ready for paint!!!
first end painted in redneck paint boot, it keep the overspray down so the neigbors dont complain.lol...
an other part in the redneck paint boot
all etched and primed, black coat going on tomorow!!!
now my back is killing me!!!
enjoy
