tire size?
Re: tire size?
hello, monkey bones, love your truck, hope you still have it. I run 38 inch tsl swampers on stock budd wheels, but looking at 42 inch. What wheel are you using. I dont think they will fit on stock budd rim. Do you have clearance in the front when turning lock to lock without the tires rubbing? Maybe you are not running the stock axles. Also, what kind of lift do you have? Just added leaves, blocks, custom springs? Sorry for all the questions but I sure like the look of your truck. The 42 inch tsl's are 3 inches tread wider than the 38,s and the center section on the 42's is 2.5 inches wider. Please let me know info, thanks.
