Anyone ever dealt with this outfit?
Nickathome
Link
Post by Nickathome »
Gary;
Thanks however the link simply takes me to an autozone website and thats it.
Nickathome
Goodies
knattrass wrote:Nick - NAPA has all the goodies - most recommend 2 shutoffs for summer and in case you spring a leak. Also be sure to get some plastic tees to help make the various tight turns. The grommets I used were also available. Grab a fist full of hose clamps!
knatrass;
Thanks. I'll more than likely hit NAPA as soon as I get the heater. I downloaded the instructions to install off of Olive-Drab. com and it lists alot of what was said here as well, so I will take the list with me when I go.
NCmountainman
Post by NCmountainman »
In regard to the plumbing, I know that one hose goes to the outlet above the water pump. Where does the other one hook up? Which one is the inlet connection at the heater?
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
1942 Chev G506 (SOLD)
Nothing is Fool Proof to a suffeciently talented fool.
Odd-it takes me right to the part-it's a #5851 heater control valve.
Ed,
The other hose goes to the plug on top at the back of the head, passenger side, about 45 degrees back of the #6 spark plug. Remove the oil bath for a clear shot at it (that's what I'm drilling out).
Hey Ed,
Check Carter's post with the pictures of Ralph's engine-it's a perfect view!
NCmountainman
:lol: Thanks guys, for all the info and advice! It will be a lot easier now when I get ready to install a heater in mine.
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
