Pintle question
peter e mark
- SSGT
Did one of you say "6' pry bar' ? Now that's the type of thinking I like. According to the esteemed annuls of advanced reenactor and military field repair logic, you treat such matters as follows: STEP ONE Force it , it will either turn, or break. STEP TWO: If it breaks, replace it....
1952 M37 W/W
peter e mark
- SSGT
1952 M37 W/W
peter e mark
- SSGT
1952 M37 W/W
Yep, I said 6' pry bar. I'm getting old enough that I don't have anything to prove now. I like being able to perform such task without over excerting the old bones. Any task such as this requires the use of common sense just the same as the proper tool for the job. No breakage will occur if using good sense along with correct tooling.
peter e mark
- SSGT
- uglyranger
- PFC
peter e mark
- SSGT
peter e mark
- SSGT
