Posted: Mon Jul 21, 2008 1:30 pm
I have done it Bruce, the M is pleasant to walk next to as in Lo range 1st it does notably less than walking pace at idle (V8 torque helps) and if done with a bit of commonsense it makes for an interesting party trick LOL
I also noted after putting the 318 in that when winching the hand throttle is no longer required, if you need to pick the revs up above 500 the load needs a fall block or is too heavy....
Take Care
Best Regards - MM
Take Care
Best Regards - MM
